An Open Source external module for powering a stock TS100 Soldering Iron using USB C Power Delivery
V1_2 EasyEDA_Project_TS100 - USB C IP2721.zipA Backup of the EasyEDA ProjectZip Archive - 52.69 kB - 02/22/2021 at 19:52 |
V1_2 Schematic_TS100 - USB C IP2721.pdfSchematic PDFAdobe Portable Document Format - 44.04 kB - 02/22/2021 at 19:52 |
V1_2 Schematic_TS100 - USB C IP2721.pngSchematic ImagePortable Network Graphics (PNG) - 34.50 kB - 02/22/2021 at 19:52 |
Zip Archive - 35.12 kB - 02/22/2021 at 19:52 |
V1_2 BOM_TS100 - USB C IP2721.csvBOM File for the projectComma-Separated Values - 1.82 kB - 02/22/2021 at 19:52 |
My first PCB design for this project was based on the IP2721, and I assembled this version on my stream this week. I'll go into more details about the IP2721 later in this update.
The stream is almost a perfect tutorial on how not to assemble things:
But all that said, we got it assembled, only to find it wasn't working as expected. It was negotiating 5V from the charger (or at least the charger was outputting 5V) rather than the 20V we expected it to.
One of the viewers on the stream mentioned that I was missing a 100k resistor between the "SEL" pin of the IP2721, the pin that dictates what voltage you want the IP2721 to request from the charger. I had it pulled high as per the data sheet, but I connected it to VCC directly.
So I lifted the IC, cut the trace to the SEL pin, leaving the SEL pin floating, which tells the IP2721 to request 15V. I reinstalled the IC, but it was still negotiating 5V. When I replaced the IP2721 we were in luck and it now negotiated 15V as expected. Also as expected, when we added the 100k resistor (as you can see in the photo) it negotiated 20V.
So a minor change and we'll be in business right? Well it's not that simple unfortunately ....
What attracted me to the IP2721 was two things: @ $0.60 in low quantities it was extremely inexpensive but the most important thing for me was that it could be configured without programming it.
From a product point of view this would be very desirable because it really simplifies the process. This is a product I want to get assembled by a fab house, so keeping it simple keeps costs down an minimizes points of failure.
The only kind of a problem was that I could not find a source of the chips that I could buy myself. But I asked my contact in Makerfabs (who are more than likely going to be the place I get them assembled) could they get me some samples and they were able to.
Basically there is certain chargers that are capable of working with the Ts100 that will not work with the board as pictured above. This was something I realized after I ordered the board. The problem is something you can figure out with the specs of the charger, but thanks to my Github sponsors I was able to buy a selection of chargers to test the reality (which was actually interesting)
Power Delivery supplies range in the watts the support, but also the voltages that they offer. The IP2721 will request the configured voltage from the PSU, but will fall back to next highest available.
Take for example this 30W supply:
Voltage | Chargers Max Current |
5V | 3A |
9V | 3A |
15V | 2A |
20V | 1.5A |
The TS100 is a fixed resistave load that works at voltage rage between 12-24V. The resistance in the heating element of the TS100 is 8.5 Ohms. If we apply Ohms law (Voltage = Current x Resistance) to for the voltages in the TS100 range, we get the following:
Voltage | TS100 Current Requirement | Chargers Max Current |
15V | 1.76A | 2A |
20V | 2.35A | 1.5A |
Notice how the current requirement for the TS100 reduces with the reduction of voltage (This does have an impact on it's heat-up time). But as you can see from the above table, this PSU is not capable of powering the TS100 at 20V, but it is capable of powering it at 15V.
The issue is while PD does support checking the max current each voltage range can supply, the IP2721 does no do this. It's negotiation with the charger is based solely on the voltage range it supports.
So if you plug the Flex-C-Friend into this charger, it will negotiate 20V successfully, but when you try to power the iron it will trigger the PSU over-current protection and it will shut the TS100 off.
This is not a good situation as the PSU is capable of powering the TS100 at 15V. You could just insist everybody...
Read more »I will be doing a livestream this evening testing out a STUSB4500 reference board to determine is it a good fit for this project.
Unlike the IP2721, The STUSB4500 has configurable power delivery profiles so we can determine if the power supply can provide enough current at the rated voltage. For a restive load like the TS100, the current draw requirement drops proportionally to voltage so it would be good to be able to set the current requirements for more than one voltage level.
It looks like the heavy lifting on developing a sketch for programming it has already been done by the Github user oxplot. Oxplot also sells a board based on the STUSB4500 on tindie, although at time of writing this he is sold out.
Come join me later if you want to hang out and watch me try this out. If it works out and we get time, I'll start designing the new PCB on stream too. Link for the stream is the youtube video below.
Brian
Although this concept had already been successfully done by several people before me, I wanted to prototype a solution to prove out
I made a couple of early prototypes of boards I called the "Flexi Friend", which was basically an Female XT60 connector and either a screw terminal or a barrel jack connecting it.
I also was wondering using these "Flexi Friends" together with existing USB-C power sink modules such as the one pictured above, would be a more economically viable product, as let's face it, this product is a very very niche thing!
You could take the existing PD adapter I'm using and plug it directly into the TS100, but the weight of the adapter and the inflexibility of the cables don't make it very pleasant.
I have been using the cable above to power my TS100 from USB-C for the last 3 months or so and I'm loving it! So much so that when I moved house, I didn't even bother unpacking the regular PSU I had for the TS100. I even have a power bank capable of delivering 60W so I can battery power my TS100 now too.
I decided to go ahead and make a PCB with the PD sink IC on to reduce the amount of adapters you need to connect in chain to power the iron. I'll cover my attempts at this in a future update!
