First Entry
A project log for 3D Printed CNC
A CNC machine made using PLA and a common 3d printer. All of the software & electronics are open source or off-the-shelf components.
elliotElliot 06/05/2020 at 04:100 Comments
Been working on this project for a couple weeks.  Hope to have something that moves by the end of the month.  See the different version iterations in the gallery.  Original idea was going to be a one piece design.  That evolved into 2 part, a block and a bearing.  Then the bearing wasnt working out great so I got off the shelf bearings.  Check points are:
  1.  Get 1 axis moving (camera slider)
  2.  Get 2 axis moving (XY Plotter/laser)
  3.  Get 3 axis moving!
