Drilled and bolted
A project log for 3D Printed CNC
A CNC machine made using PLA and a common 3d printer. All of the software & electronics are open source or off-the-shelf components.
elliotElliot 06/13/2020 at 05:220 Comments
Drilled and bolted the frame.  Cut the sub-board crooked :(. Getting binding and all sorts of twisting.  I could get some movement for the sake of it, but this is definitely making it to a beta version.  Need to spend more time in CAD.  I do have parts for a brushless spindle on the way.
