Octoshield
Octoshield is a Raspberry Pi shield to help with 3D printing and Octoprint.
Octoshield is a Raspberry Pi shield to help with 3D printing and adding features to Octoprint.
This project is made to help using the Enclosure plugin available for Octoprint by providing a simple interface to connect RGB LEDs, fan, input switch, temperature sensor and more.
The Octoshield also include a buck regulator to power a Raspberry Pi with a 12v supply.
Be careful to set it to 5v before connecting ANYTHING !
Here is the Enclosure plugin : https://plugins.octoprint.org/plugins/enclosure/
The plugin is realy easy to use and allow you to configure inputs and outputs using the GPIO pins.
Here is the pinout used :
RaspberryDirectionFonction
GPIO_4
InputData line for DHT11/22
GPIO_5InputButton input (ON/OFF)
GPIO_9OutputNeopixel data line
GPIO_17OutputRed channel (PWM)
GPIO_18OutputRelay command pin (ON/OFF)
GPIO_22OutputBlue channel (PWM)
GPIO_23Output12v fan command pin (PWM)
GPIO_27OutputGreen channel (PWM)
components list example.xls
Componants list from Mouser
ms-excel - 113.00 kB - 06/05/2020 at 20:31
Download
octoshield v2.0.zip
Kicad project
x-zip-compressed - 229.29 kB - 06/05/2020 at 19:01
Download
gerber.zip
Gerber files for manufacturing
x-zip-compressed - 145.48 kB - 06/05/2020 at 18:58
Download
  • 1 × Capacitor SMD 1206 4.7µF capacitor
  • 3 × 220Ω Resistor SMD 1206 220Ω resistor
  • 1 × 12V DC Jack BarrelJack_Wuerth_6941xx301002
  • 2 × 3 pins fan header FanPinHeader_1x03_P2.54mm
  • 1 × 4 pins header PinHeader_1x04_P2.54mm
View all 18 components
  • 1
    Build Instructions
    The board is using a mix of SMD and THT components but everything can be solder with a simple soldering iron, starting with all the SMDs before the through hole components on the top face and then the bottom face.
  • 2
    Plugin configuration
    The board was design to be used with the Enclosure plugin, of course you should start by installing it.
    Configuration is done by going into Settings/Enclosure Plugin, here you can configure inputs and outputs as you want.
    Output config
    Input configuration
View all instructions
