Energy and Water Mushroom
Energy and Water Mushroom, provides for a wind turbine, a cistern for rainwater, 4 solar panels, a hydroelectric generator...
Public Chat
My project (Energy and Water Mushroom), provides for a wind turbine with vertical blades about 1 meter high, a cistern capable of collecting rainwater (about 1.5 meters high and with a diameter of about 2.7 meters), 4 solar panels with a power of about 200-300 watts each, a hydroelectric generator with a power of about 60/100 watt, a battery energy accumulator and an inverter from 12 VDC to 220 VAC.
Project considerations:
Given the large size of the project, I had to make a scaled-down version that allows you to understand how to make the larger version. Many changes can be made to suit your needs; from the dimensions to the material of the tank; from the power of the solar panels to the power of the hydroelectric generator, from the power to the size of the wind generator, etc.
My project (Energy and Water Mushroom), provides for a wind turbine with vertical blades about 1 meter high, a cistern capable of collecting rainwater (about 1.5 meters high and with a diameter of about 2.7 meters), 4 solar panels with a power of about 200-300 watts each, a hydroelectric generator with a power of about 60/100 watt, a battery energy accumulator and an inverter from 12 VDC to 220 VAC. Rainwater, falling inside the upper part of the mushroom, passes through a tube or slides through the mushroom hat inside the tank. By opening the tap, the water flows through a hydroelectric generator which, in addition to supplying the water, generates a current that recharges the internal batteries of the mushroom. In the central part of the mushroom, a wind turbine with vertical blades is installed which, in case of wind, generates current and charges the batteries installed inside the mushroom. There are also four solar panels, which open as soon as they are irradiated by sunlight, storing energy in the batteries inside the Energy Totem. The energy stored by the batteries can be used to power the devices in the house such as: appliances, bulbs, etc.
The four solar panels, which open as soon as they are irradiated by sunlight.
2_Energy and Water Mushroom.stl
Print 1 pcs of this file for Wind Generator
Standard Tesselated Geometry - 328.11 kB - 09/02/2020 at 04:57
Download
1_Energy and Water Mushroom.stl
Standard Tesselated Geometry - 1.04 MB - 09/02/2020 at 04:56
Download
JPEG Image - 3.01 MB - 08/28/2020 at 11:50
Preview
Download
JPEG Image - 3.05 MB - 08/28/2020 at 11:50
Preview
Download
This is the scaled-down version of the wind generator and 3D printed
JPEG Image - 64.30 kB - 08/28/2020 at 08:11
Preview
Download
View all 10 files
View all 6 components
View all 4 project logs
stuartplunkett94 wrote 07/02/2020 at 14:10 point
why did you chose to only use 1 piston for each solar panel? i think if you had 2 each and a pivot point, you could angle all of them to the sun for greater power generation
Vittorio Loschiavo wrote 07/02/2020 at 18:48 point
Yes, Your idea is good, I think to modify it as you suggest.
[deleted]
Vittorio Loschiavo wrote 06/29/2020 at 20:29 point
Who are you? I didn't write no article. My antivirus and browser have told me that your link is very dangerous !!! Please let me know. I have intention to write to Hackaday to report this message.  I will wait for your answer until tomorrow.
