Part number: PC410L
Description:
PC410L is is a optically contained coupled LED to an OPIC chip configuration, it is fabricated and designed for the fast speed characteristics and minimum switching loss. Uses in large power inverters and programmable controllers to achieve high input impedance and high power transmission.
Features and Specifications :
  • High speed responses and maximum stability of 50 Nano per second
  • High and instant speed isolation voltage between input and output transition 3.75 kV
  • Maintains high noise immunity due to high instantaneous common mode voltage rejection.
  • For slow soldering double transfer mold package
Pinout Configuration and Schematic:
The pinout configuration and schematic of the PC410L is
Pin Number
Pin Name
Pin Description
Pin 1
Anode
The pin 1 is a anode pin configured with the diode
Pin 2
Pin 3
Cathode
The pin 2 is a cathode pin connected in reverse bias
Pin 4
GND
The ground pin is base to the configured pins
Pin 5
Open collector
The Amp configured pin is open collector pin
Pin 6
Power supply
Pin 6 is the power supply pin configured
PC410L schematic arrangement and design
Applications:
  • Used in the programmable controllers
  • Application in the power inverters and source inverters
  • For the fast switching speed controllers and processors
Video on Youtube:
