Part number: TDA8954TH
Description:
The TDA8954TH is a2 channel audio power amplifier which uses the class D technology for the power amplification. The audio signals are converted into pulse width modulation, TDA8954TH is a class D mono high-efficiency or stereo power amplifier with a single designed low power dissipation. The combined audio frequency of class D with audiophile sound quality is associated with the classification of AB amplifiers. It is supplied with diagnostic pins configuration for the monitoring status of fold black and other elementary component protection circuits.
Features and Specifications :
  • It is 2-pin diagnostic for protection of circuits
  • The TDA8954TH has zero dead time switching
  • Available with BD modulation in BTL configuration
  • The current switching and quiescent is low
  • Fabricated and consists thermal Fold Black with disable functionality
  • Consists of a smooth pop noise free start-up and switch off functioning
Pinout Configuration of TDA8954TH:
The pinout configuration and pinning information is
Pin Number
Pin name
Pin Description
Pin 1
VSSA
negative analog supply voltage
Pin 2
SGND
signal ground
Pin 3
VDDA
positive analog supply voltage
Pin 4
IN2M
channel 2 negative audio input
Pin 5
IN2P
channel 2 positive audio input
Pin 6
MODE
Termed to mute or operating mode
Pin 7
OSC
oscillator frequency adjustment or tracking input
Pin 8
IN1P
channel 1 positive audio input
Pin 9
IN1M
channel 1 negative audio input
Pin 10
DIAG1
diagnostic output 1 (open drain; TFB)
Pin 11
OSCREF
reference for OSC pin
Pin 12
DIAG2
diagnostic output 2 (open drain; protection function)
Pin 13
PROT
decoupling capacitor for protection (OCP)
Pin 14
VDDP1
channel 1 positive power supply voltage
Pin 15
BOOT1
channel 1 bootstrap capacitor
Pin 16
OUT1
channel 1 PWM output
Pin 17
VSSP1
channel 1 negative power supply voltage
Pin 18
STABI
decoupling of internal stabilizer for logic supply
Pin 19
n.c.
not connected
Pin 20
VSSP2
channel 2 negative power supply voltage
Pin 21
OUT2
channel 2 PWM output
Pin 22
Pin 23
BOOT2
VDDP2
channel 2 bootstrap capacitor
channel 2 positive power supply voltage
Pin 24
VSSA
Applications:
  • Used in Home Theatre system system box extension
  • Application in mini and micro receiver system
  • DVD, subwoofers power systems
  • Public address power system
  • High power speaker system
Video on Youtube:
