Marking the project completed
A project log for An NTP server using GNSS for time
A straightforward project to use an old Raspberry Pi
ken-yapKen Yap 08/18/2020 at 10:200 Comments
The RPi has been running for a while now. The last thing I did was to cut away a panel of the acrylic case so that the GPIO flat cable can enter the box with the cover on. It's strange the makers of the case didn't consider this but I suppose most buyers, including me, ended up using the RPi as a cheap Linux machine and not as a hardware experimentation platform like the Arduino.
So I'm marking this project completed. If I add other capabilities to the RPi, like bluetooth comms, I'll start a new project.
