Started PCB design
A project log for VGA video generation card
16 bit VGA interface, 32K colors, graphic 640x480, sprites, sound, intended for Kobold K2 computer, no special video chips.
roelhroelh 06/11/2020 at 20:461 Comment
PCB design was started.
The dimensions will be just below 10 x 10 cm. DIN 41612 connector at one side. All SMD devices.
4 layer pcb.
The upper part of the pcb is now routed for the most part. In the lower part you see the ratsnest of connections that are waiting to get routed.
Dave's Dev Lab wrote 06/12/2020 at 21:31 point
nice looking layout!
