First model hot off the printer
A project log for Clear N95 + Mask , 3d Printed & Vacuum Formed
Covid-19 and Flu, 3d Printed and Vacuum Formed for Cerebral Palsy, Hearing Impaired, Deaf, Autistic and Elderly
josh-starnesJosh Starnes 06/09/2020 at 23:060 Comments
This model printed well at 19 hours long. We will work to get print times down as the parts are made thinner and frame thickness is reduced. Frame material thickness is 5-6 mm here. Please welcome our handsome model as he shows how closely the mask fits to the face without pressing or an adaptable seal. The cheek curvature and  nose bridge gaps need to be adjusted and then we will start working on a seal.
