Got some flash dumps!, I think...
A project log for Playing with the Starbridge Lynx 210
A research project on a 3.74$ router I got from Goodwill
jose-ricardoJose Ricardo 06/09/2020 at 07:020 Comments
So, I remember reading about mtd partitions somewhere, and at the time I'm writing this log I believe they represent flash memory in embedded devices or something.
After what I can only describe as a painfully long ordeal, I set up a tftp server on my laptop and I managed to dump all of the four partitions to it. I'll now be using Ghidra to see which one of them is the bootloader, (I mean, I know it's mtd0 from the serial port logs, but I just want an excuse to use Ghidra). I'll see if I can also take a look at the SquashFS image and change the contents of it.
I'm not entirely sure as to if I can upload the binaries somewhere, but I'll see if I can later built a small (and more modern) Linux image and publish that instead.
I just used this command to dump the mtd partitions into files on my laptop:
tftp -p -l /dev/mtdblock/0 -r /mnt/tftp/mtd0.bin 192.168.1.2 69
