muRLi - A WiFi connected and programmable (mu)sic (R)eactive (Li)ght system
muRLi is a wireless connected mesh of LED nodes which are synchronously reacting to music/sound. Using a EEPROM cartridge for scripting.
Public Chat
muRLi is a WiFi connected and programmable (mu)sic (R)eactive (Li)ght system. It supports custom MOD cartridges which contain executable scripts. These scripts are able to influence the light patterns produced by muRLi.
Furthermore muRLi creates a naive mesh including a websocket. muRLiNs (muRLi nodes) are able to connect to this mesh and will create an additional access point and websocket for other nodes to connect to. This way nodes not in range of muRLi are also able to join the mesh as long as at least one muRLiN is in range. The nodes are able to receive commands created by muRLi. The commands contain color information to which the muRLiNs will react.
Everything combined, it is possible to span a mesh of WiFi connected devices which are synchronously reacting to music.
Writing a project log here & maintaining the build instructions on https://github.com/geaz/murli
1x Top.stl
muRLi Shell - Top
Standard Tesselated Geometry - 270.79 kB - 06/09/2020 at 05:22
Download
Mod Top.stl
MOD Shell - Top
Standard Tesselated Geometry - 5.65 kB - 06/09/2020 at 05:22
Download
Mod Bottom.stl
MOD Shell - Bottom
Standard Tesselated Geometry - 4.67 kB - 06/09/2020 at 05:22
Download
4x Bolt.stl
muRLi Shell - Bolts
Standard Tesselated Geometry - 134.65 kB - 06/09/2020 at 05:22
Download
1x Bottom.stl
muRLi Shell - Bottom
Standard Tesselated Geometry - 258.87 kB - 06/09/2020 at 05:22
Download
View all 8 files
  • First version done!
    Gerrit06/24/2020 at 12:17 0 comments
  • First version of muRLiN firmware done!
    Gerrit06/20/2020 at 19:00 0 comments
    Finally the muRLiN (muRLi Nodes) software is done!
    I wrote a complete overhaul of the script engine which is now using mJS. I also implemented some API methods for the scripts. For example a "setDelay" method. With this method it is possible to delay the frequency updates.
    The script in the video is using this method to create a running light which is syncronized beyond two nodes!
  • Base station done - Working on the Nodes now
    Gerrit06/09/2020 at 05:21 0 comments
    The base station - muRLi itself - is mostly done now. Here a small video of it:
    I am now working on the Nodes (muRLiNs). I hope I will finish the software part this week and the hardware in the coming week. The nodes will also use a Wemos D1 Mini which will scan for a available muRLi network.
View all 3 project logs
View all instructions
Dan Maloney wrote 06/09/2020 at 17:02 point
Love the look of this, and that EEPROM cartridge design is great.
