Hardware
Ralink RA5350 SOC (recovered from an old SRICAM AP-009 IP Camera)
1x MIPS-32 core @ 360MHz
32mb RAM
8mb Flash
USB Lithium charger
DC-DC boost converter
Li-Po Battery's 3x 1100mAh (when they where new)
Software
OpenWrt 19.07.2
Travelmate plugin
OpenVPN
Performance
Speed tested around 13 Mbps Down & 8 Mbps Up (without VPN)
Speed tested around 3 Mbps Down & 2 Mbps Up (with VPN its a bit CPU limited...)
General use, Streaming, surfing gives in excess of 5 Hrs on the Internal Battery
READYWARE
tomwsmf
chris jones
Valent Turkovic
