Brake actuator in action
A project log for WinDIY - HAWT Wind turbine
Mostly 3D printed HAWT windturbine incl. 3D printed disk-generator and brake system.
FabFab 10/05/2020 at 11:540 Comments
Here is a small video from the first successful test of the brake actuator on my test stand. The generator is driven by a 250W motor. It is regulated down to approx. 20% via the PWM of the speed controller. The brake pressure could also be increased.
