Ver 1 bag
A project log for Field Ready-Nebula Gel IV Blood & Fluid Warmer
Gel based IV bag warmer for blood, saline, antibiotics and more, optional field battery with 12v, 24v, 110v, 220v power options
josh-starnesJosh Starnes 06/21/2020 at 07:220 Comments
This is the first bag, so I will still be trying out various ways to construct it. This first try I am pulling a length off the roll , sealing each end first then spot welding it to better maintain a more uniform shape. I have found this end up with far room much material and I ended up with air in the system which is something I want to avoid. I would like to reduce the profile to a single layer of water beads and then fill the voids completely  with water.
