Hive is based on ESP32 for Wi-Fi connectivity and Bluetooth for fast pairing process with mobile device. The ESP controls 5 meter ws2812b LED strip (300 LEDs) so at max power it can draw 5v@18A.
To avoid that power consumption when I what it to glow in white I'm going to replace the LED strip with RGBW strip for pure white color.
Hive has a concrete base to make it stable.
It took me two tries to make it work. In the first one I was impatient and I've tried to demold it after 2 days and it cracked and broke.
For the second try I've waited week and a half and it came out perfect.
You can find the source code for this project in my GitHub repository that linked to the project.
Tovi Levis
