LLTP has a display
A project log for LLTP - Light Logic Transistorless Processor
My attempt to create a CPU/MCU without transistors or relays
dr-cockroachDr. Cockroach 03/20/2021 at 23:062 Comments
March 20, 2021 - I'm back and melting solder once again. I adapted the hex display used on the Cardboard Computer - IO project and replaced the transistors with Light Logic. The display is not perfect by a long shot but it does work.
Paul McClay wrote 03/22/2021 at 06:56 point
Would be hard to choose a more appropriate display!
Glad you felled the fell virus.
Dr. Cockroach wrote 03/22/2021 at 08:15 point
Thanks Paul, yeah I tend to do things the hard way and staying with diode only logic has caused a few of my remaining hairs to get whiter but amazing what can be done without using transistors ;-)
