Mid September state of the LLTP
A project log for LLTP - Light Logic Transistorless Processor
My attempt to create a CPU/MCU without transistors or relays
dr-cockroachDr. Cockroach 09/13/2020 at 16:560 Comments
September 19, 2020 - I decided that I need to start adding labels to the LLTP to indicate what is what. Even I will get confused later as I add more registers.
September 14, 2020 -  Just a brief update of where I am with the LLTP project. I am currently matching up CdS photo resistors and making a batch of 80 Light Logic opto-couplers and those will be used to wire up four 4 bit registers. These will be used for the Program Counter, Instruction Register and the A and B input Registers for the Adder.
That's enough couplers for two 4 bit registers.
