Final end of 2021 Circuits for Light Logic Gates
12/31/2021 at 23:52 • 0 commentsDecember 31, 2021
Not earth shattering but here are the final circuits for Light Logic. Happy New Year to everyone.
A little improvement on the XNOR gate
12/28/2021 at 14:14 • 1 commentDecember 28, 2021 - After a bit of an absence I started improving on some of my Light Logic gate circuits. I was never satisfied with how my XNOR gate turned out so I ended up having a dream last night and when I woke up this morning I got to working on what I had dreamed about. The simple change is that I now feed 5 volts to the inputs continuously through a pair of 150R resistors. If there is no input at either A or B then the input is considered HIGH. If either A or B is grounded through a previous gate then the input is LOW. The Out of the LDR can be followed by a Light Logic Inverter gate to create a XOR gate or wired to any other gate as needed. I have this circuit on a bread board and it is working as it should. Remember, with Light Logic the output MUST be through the LDR to ground to be a counted as a solid Zero / Low. Anything else is counted as a One / High
As small as it gets for now
11/01/2021 at 21:52 • 7 commentsNovember 1, 2021 - Finally finished up the newest D-Latch with a added output buffer. This build works just as well as the wall mounted LLTP D-Latches and is about as small as I can make with my standard way of hand making my Vactrols. The solder side is not pretty but the same layout as if it were a PCB.
Just to recap, the added output buffer is needed as the Q output can be de-latched when fed directly to the next stage such as a adder or another part of the processor.
A new smaller look
10/25/2021 at 16:54 • 0 commentsOctober 25, 2021 - I have been idle on the LLTP for a little longer than I wanted but I have been doing a bit of mind games on where to go with the construction of this 4 bit no transistor processor. I am trying out my standard Light Logic Vactrol devices on a copper perf board and making the parts placement as tight as I can. The follow images look promising and show the partial wiring of a one bit latching memory. So instead of a design that will take up the walls of my lab, the new reduced design will only take up a table or desk top or mounted on something like a motherboard.
August 19, 2021 - Just Hanging Around....
08/19/2021 at 12:22 • 0 commentsFinally getting the LLTP hung onto the lab wall like I wanted from the start of this project.
All Led NAND Gate
04/06/2021 at 10:33 • 0 commentsApril 6, 2021 - just for grins and future use. A Light Logic 4 input NAND gate where all the diodes are Leds and in free form without the paper and fasteners.
LLTP has a display
03/20/2021 at 23:06 • 2 commentsMarch 20, 2021 - I'm back and melting solder once again. I adapted the hex display used on the Cardboard Computer - IO project and replaced the transistors with Light Logic. The display is not perfect by a long shot but it does work.
Comming back to life
01/21/2021 at 01:25 • 5 commentsJanuary 20, 2021 - Well now, where to begin. My last entry was on December 5th and the very next day I started feeling a bit odd. My sense of smell and taste vanished in a matter of days and just felt weak. By Dec 10th I had lost 10 pounds of fluids and I felt that I had to go to the ER. Many tests and scans done and YUP, Covid-19. I was put on IV and felt a little better after that but for the next 4 days I was running a fever that would not break. I was having a hard time breathing by this point so off to the ER again. CT scan did not show any lung issues to be worried about but was given another IV, That's now two liters plus a steroid of some sort. Given a script and went home. The fever broke about four days later and I have been making slow progress. Now by Jan 20 I have my energy back in full though still have a bad cough from time to time. This has been a roller coaster ride that I would not wish on anyone. My appetite has also changed as I feel hungry but can only manage about half of what I used to eat. After my fluids were back to normal and my weight briefly returned to 254 pounds. My reduction in eating has me down to 239 as of this morning. I look forward to losing some weight but by way of the CV is not advised.
I will get back to this project as I have sat on my arse for too long :-)
Coming out of hibernation
12/06/2020 at 01:14 • 0 commentsDecember 5, 2020 - I have been working on other projects for a while and let the LLTP take a bit of a deep sleep. It is just about time to warm up the iron and wake this project up once again :-)
Yet Another Register
09/24/2020 at 23:58 • 0 commentsSeptember 24, 2020 - Yet another register about to be born. Number three in this case.
