First problems
A project log for HDD Delta Robot
This is the attempt of building a delta robot using parts from HDD and my parts bin, I'll go as far as I can.
omarOmar • 07/28/2020 at 07:11•0 Comments
Well I know this will happen, is normal and life will be boring without problems, also problems makes success more satisfying when it's achieved.
As I advance on the circuit I also do tests, the first test was with only one VCM connected to LM298HM, at that time I don't see any aparent problem, but when I did test with two VCM connected to L298HN I noticed a voltage drop on the ouputs of L298HN to both VCM from 4.5V to 3.23V, I also measured voltage drop at output of the variable power supply (LM350K based), this tell me that voltage drop was on variable power source, so I made a test connecting both VCM in parallel direct to P.S. output, test conditions was:
If you see there is a voltage drop of 1.6V on Vout when load is connected to P.S. I need to check the datasheet to find what is wrong here (or if this is normal). Also there is a voltage drop too if I use only one VCM but is low enough to overlooked it on first tests, so if I connect three VCM then the voltage drop will be more than 1.6V (however I don't tested it).
This is the used circuit (from TI datasheet):
And this is the implemented circuit:
D1 and D2 are 1N4006, C1 100nF, R2 is a 25k pot.
I don't think this problem is thermal related because LM350K use a large heatsink and the changes on Vout are fast as the change of load. Well I will start here the analysis to find the possible problem, wish me success.
