Power stage done.
A project log for HDD Delta Robot
This is the attempt of building a delta robot using parts from HDD and my parts bin, I'll go as far as I can.
omarOmar • 09/08/2020 at 05:52•0 Comments
Hi, finally power stage board is finished, the next step is do more test and maybe make a cable harness for all inputs, outpus and supply.
This is the power stage board (top side):
Bottom side:
Isn't the best circuit board that I have done but is functional, at least on brief test, if all other test go well I will make a schematic on KiCAD.
