More problems
A project log for HDD Delta Robot
This is the attempt of building a delta robot using parts from HDD and my parts bin, I'll go as far as I can.
omarOmar 08/25/2020 at 08:320 Comments
My laptop HDD failed, all the info about this project are on google drive so I simply replace the HDD and reinstall Linux, there is the problem, before the failure I have Ubuntu 18.04 LTS with the IDE for XMOS startkit board xTime Composer, all was working fine and the IDE can connect to the startkit without problems, until now....
My laptop is old, so I installed lubuntu, the problem: there is no USBFS support, because has been deprecated, so I must create rules file for udev in order to mount the board, that is covered in this XMOS document, but after creating the rules for udev on /etc/udev/rules.d/ disconnect and connect the board and doing a service reload to udev the IDE didn't see the XMOS startkit, using lsusb command I can verify detection of the board, I think that maybe the rules file have problems.
So I need to fix that in order to continue with the XMOS startkit board, may be this take some time due my work and my family and add that I'm not an expert in linux...
