Evaluate Control Parameters
A project log for Vintage Electricity Meter
Vintage electricity meter gets new life with WiFi control.
karstenKarsten 06/14/2020 at 14:450 Comments
The basic function work quite nice, for a given PWM value, the rotation speed of spinning disk convergates to an according value. However the transient response is quite long (about 6 minutes).
The damping factor in cause of friction seems for a large range constant, only for slow velocities it seems higher.
With a few more experiments and analytical consideration it should be possible to create a (open-loop or closed loop) control circuit which takes a specific speed as set point.
