In this tutorial, we are going to make a simple "LED Chaser Circuit using CD4017 & 555 Timer IC".
PCB Prototype for $5 Only (Any Color): ►► https://www.pcbway.com/?from=cdiy2020
#CircuitsDIY
Find Full Project Description & All Useful Material Including
• Circuit Diagram / Schematic
• Hardware / Component List • Codes / Algorithm • Datasheet / Pin Configuration etc
At ►► https://circuits-diy.com/circular-led-chaser-usin...
Step 1: Hardware Required
To Buy Cheap Electronic Components Please Visit : UTSource
Step 2: Solder Both IC's
Solder Both IC's
Step 3: Place IC in Base
Place IC in Base
Step 4: Solder Resistor & Trimmer
Step 5: Solder Capacitor & DC Power Jack
Step 6: Solder All LED's
Solder All LED's
Step 7: Let's Test the Circuit
Step 8:
