Re-Engineered Landing Gear Mounts
A project log for OPEN SKY ANCHOR 5G WIFi DRONE
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
Josh StarnesJosh Starnes 09/17/2020 at 12:070 Comments
Let me say, the standard landing gear mounts that come with " heavy lift" kits. Basically the ones that are taller and raise the drone up off the ground. So as with everything else on this machine I and Thurindu have engineered a two piece clamp style that is much easier to remove and make adjustments to. The part is already so small there is no room for weight reduction, instead I added strength and functionality for approx the same weight.
