V3 Update 2 , ESCs fitted
A project log for OPEN SKY ANCHOR 5G WIFi DRONE
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
Josh StarnesJosh Starnes 09/25/2020 at 11:480 Comments
Two zip ties on each set of ESCs hold them securely under the arms. They are vented from the top , sides and open bottom so cooling should not be an issue. There are two 30a ESCs beside each other in this arrangement.
