TA DA, power supply ready to test
A project log for OPEN SKY ANCHOR 5G WIFi DRONE
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
Josh StarnesJosh Starnes 09/28/2020 at 02:300 Comments
I have heatsinks and fans now. It is time to start testing the power supply, first that it puts out clean 12volts and second that it can handle a load up to the full 500 watts. We will use the Flir camera on this one as well as a thermometer device to monitor temps. Also we may have an oscilloscope to check the power output is clean as well. ( I mean it should be with as many chokes, capacitors and voltage dependent resistors in the circuit.
