The V5 Wifi Array Gimbal Gets a Weight Reduction
A project log for Open Sky Anchor WiFi Drone Brings The GIG
Mission "Wifi" Impossible > Bring Long Range 5G and 2.4 G WiFi Backed By A 1 Gigabit Fiber To The East Brainerd EF-3 Tornado Disaster area.
josh-starnesJosh Starnes 09/13/2020 at 04:390 Comments
Sometimes it is hard to tell what the actual weight will be due to support filament during prints, but I believe I have shaved off at least 50 percent. Thurindu made changes first then I went over the edges with a fine tooth comb to reduce it even more. It is basically a skeleton in comparison to the first one. Like my friend DInk says, Build it to fly not to crash! I think he means as long as it works in the air, that satisfies all the parts requirements. This is an 11 hour print so we will get pictures of these bad boys tomorrow and also a weight in.
