Not that I like to highlight failures, but these power supplies popped way under their rated load. Everyone likes to see things explode though right?! one PSU seems to have a short on the Neutral Mains in line, it immediately pops the fuses when plugged in, the second power supply seems to be working however. I already have suitable ( and more expensive) kind of power supply I posted about earlier.
This failed at about 35-40 percent throttle. I can build a custom one with much higher capacity, it is just a waiting game on parts and spreading things out over paydays. This will not keep sky anchor from flying though, there are options :)
