Let me say, the standard landing gear mounts that come with " heavy lift" kits. Basically the ones that are taller and raise the drone up off the ground. So as with everything else on this machine I and Thurindu have engineered a two piece clamp style that is much easier to remove and make adjustments to. The part is already so small there is no room for weight reduction, instead I added strength and functionality for approx the same weight.
