If you take a look at what's needed for these rollers to actually work, you can see it's never going to fit this way. And static or 'roll your own date and watch it wiggle' digits are a no-go for me.
The whole thingamajig with the gears in the middle left is the stuff that makes those numbers roll over.
There is no way I can get this to work functionally I think.
If you look at the stickers, it seems the numbers would be off in size as well:
Unless I can source smaller rollers, let's hope the OLED screen(s) will fit when they come in!
Vincent
