Good news everyone! The OLED displays got in, and I couldn't help but do a proof of concept fitting test.
I hooked the OLED up to an Arduino Uno, as I only have 1 Artemis Nano board (and I don't want to mess that one up so early in the project!). I downloaded the Adafruit libraries for this thing, and lo and behold the screen fit and worked!
I disassembled the Holotape Deck and cut out an initial hole for the OLED to show through.
Here's the initial quick & dirty result:
Unfortunately the display is not long enough to cover all of the digits for the timer/counter, so I might have to fit in two displays (I do hope I can drive two of them at the same time!).
It will all depend on whether or not I can drive two screens with one Artemis Nano. I did find the code for it on the Adafruit's forums, so there's that:
#include <Wire.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
Adafruit_SSD1306 display2(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
void setup() {
display.begin(SSD1306_SWITCHCAPVCC, 0x3C); // Default OLED address, usually
display2.begin(SSD1306_SWITCHCAPVCC, 0x3D); // Second OLED address, via onboard jumper
display.clearDisplay();
display.setTextSize(1);
display.setTextColor(WHITE);
display.setCursor(0,0);
display.print("Display A");
display.display();
display2.clearDisplay();
display2.setTextSize(1);
display2.setTextColor(WHITE);
display2.setCursor(0,0);
display2.print("Display B");
display2.display();
void loop() {
It does mention I2C address-changing jumpers, so I got to check if mine has these or not.
Anyways; the journey to creating a fully functional Pip-Boy has gotten a few extra miles on the meter!
In the mean time I'm still waiting for the Dial Motors and LiPo batteries to arrive. As soon as I have some more information regarding any of the modules, expect a new Project Log!
Vincent
