TDA7294 description
TDA7294 integrated circuit is an IC made of group of circuit which is manufactured in a single piece of silicon which is called monolithic. It main function is use in class AB amplifier in HI-FI application. The multiwatt15 package gives it ability to handle more power than one made in TO-220 or TO3 cases. It has a wide range of voltage and high out current it can supply highest power for both 4W and 8W loads. The supply of power can even happen during poor supply regulation and high supply voltage rejection.
TDA7294 amplifier can operate at 80 V voltage supply delivering an output current of ±10 A due to it monolithic characteristic. The application in class AB amplifier is because its combined advantage of class A and B where it minimizes the problems of distortion and low efficiency associated with them.
TDA7294 Pin configuration
Pin No. | Pin Name | Pin distribution |
1 | Stand-by GND | Standby GND |
2 | Inverting input | Inverting input signal input |
3 | Non-inverting input | Non-inverting signal input |
4 | SVR | Supply voltage rejection |
5 | NC | No connection |
6 | Bootstrap | Used to step-up charge |
7 | V+ | Positive supply |
8 | V- | Negative supply |
9 | Stand-by | Standby control pin used for low power mode |
10 | Mute | Terminal output is disabled |
11 | NC | No connection |
12 | NC | No connection |
13 | V+ | Positive power supply |
14 | Out | Output pin |
15 | V- | Negative power supply |
Equivalent IC for TDA7294
NTE7165
Alternative IC for TDA7294
TDA7293, TDA7295 and LM3886
TDA7294 specifications and features
It has built in circuitry function for muting which turn on the delay and help avoid switching on-off noises by simplifying the remote operation.
- High output power up to 100 W
- High range of voltage operation of
- No switching ON/OFF noise
- It has short circuit protection
- DMOS power stage
- Thermal shutdown
- Built in muting function
- Low noise
Working principle of TDA7294
Input resistor is connected on the non-inverting terminal; on the inverting terminal another resistor is connected. Another resistor which as a feedback is connected between the output and inverting terminals and it decides the loop gain of the amplifier. On the mute terminal registrar and a capacitor are connected in parallel which are used for deciding mute time constant.
Application of TDA7294
It is mostly used in components circuits that require amplification to have high efficiency and high power.
Bridge application circuit – two TDA7294 manage output signal, the load value for this configuration must not be lower than 8 Ohms. The advantages of bridge configuration amplifier are high power with low voltage and large amount of output power even when load value (8 Ohms) is high.
Other applications for TDA7294 are HI-FI, Subwoofer, Audio class AB amplifier and many other audio related applications
Video on Youtube:
