HOW TO SETUP THE ARDUINO MKR 1300
The Arduino MKR 1300 comes equipped with the ATMEL SAMD21 bridged with a LoRa module thus allowing for remote IoT applications for instance
0 followers
MKR 1300
The Arduino MKR 1300 comes equipped with the ATMEL SAMD21 bridged with a LoRa module thus allowing for remote IoT applications for instance mining, off-shore rigs, and farms. It has been designed to integrate SAMD21’s low power consumption and high performance while maintaining Arduino’s ease of use.
Setting up the MKR 1300
Step1: Arduino IDE
Download the latest Arduino IDE from their official website.
Step 2: Installing Arduino IDE in the board
Start the IDE. Give a couple of minutes for it to open up. Click on Tools, then select Board and then click on Boards Manager. Enter ‘MKR’ on the board manager’s search bar. From the results, select the result “Arduino SAMD Boards” and then click install. This process takes some time so be patient.
Read more us here at https://blog.enrgtech.co.uk
HOW TO SETUP THE ARDUINO MKR 1300.pdf
Adobe Portable Document Format - 369.43 kB - 06/17/2020 at 09:41
Preview
Download
