I collected some electronic circuit boards from old electronics appliances like CRT monitors,televisions etc..
2
Step2
collected components like:-
capacitors resistors electret microphones ICs relay modules Transistors Diode some other strange components which seems useful I purchased some leds, brass rods,batteries...etc from nearby electronics shop
prefer to collect old electronic circuit boards because they have large components compared to new boards. Then i planned some models in mind and created a rough drawing. I created the platform with a wood plank.
3
Step 3
Creating the Concert Sculptures
I Created Musical Instruments,Speakers and human models to fill concert stage. Made a stage light with some brass rods and led, I cut the wooden plank to create the base. Then i fixed the models i created using the scrap electronics in the wooden base.
Those interesting LED bodies really make this one special. I like the depth of having two sets of brass frames with the batteries sandwiched in between. Taking the photo on a mirror is also a fantastic touch. Every bit of this one is delightful, well done!
This is just amazing idea carry on working on this project you will succeed one day I also started new inline skates project you can see here.
