v2.3
04/25/2021 at 17:28 • 0 comments- update kicad_auto which includes kibot v0.11.0
- update kicad-diff to latest version
- running multiple *.kibot.yaml files is possible by executing
- a bundle eg
kicad-exports -c config/bundle/documentation.default.kibot.lst
. The file ending.kibot.lst
is a used for textfiles listing all kibot.yaml files. - or with wildcards
kicad-exports -c config/*.kibot.yaml
- a bundle eg
- refactored all config files
- you con now generate zip file of generated output
- refactored tests
v2.1 is out
11/09/2020 at 19:58 • 0 commentsv2.1 has been release a few days ago but i somehow forgot to promote it:
Changelog:
- update kiplot to kibot v0.7.0
- *.kiplot.yaml files now have to be called *.kibot.yaml!
- path of pcbdraw changed, please use:
style: '/usr/share/pcbdraw/styles/jlcpcb-green-hasl.json'
libs: ['/usr/share/pcbdraw/footprints/KiCAD-base']
- using docker image
setsoft/kicad_auto:10.4-5.1.6
instead of including all packages by myself - enable verbose output in CI runs
- add codefactor.io
- fix file permissions
I am currently already working on v2.2. As kibot 0.8.0 is currently in the pipeline this is something I am waiting for and it will enable some nice things. Additionally I am working on more predefined config files which will generate outputs fitting special needs, eg a BoM in a format compatible to JLCPCB or plotting PCB renders in oshparks famous purple/afterdark colors. so stay tuned!
v2.0 is out!
08/09/2020 at 08:12 • 0 commentsThis new release does include some major changes. Now you can write own config files to specify the kind of output you want to be generated.
next version upcomming
06/25/2020 at 14:22 • 0 commentsI am currently working on a few improvements
- added KiCad-Diff https://github.com/Gasman2014/KiCad-Diff
- removed PcbDraw as I never made it work properly
- set timestamp of gerber files according commit time
- updated submodules
what else would you like to see?
