Educational Five-Bar Parallel Robot (Double SCARA)
Designed to be used as a first robot to introduce students to robotics concepts such as : Inverse Kinematics and control algorithms.
With this planar robot you can play with forward and inverse kinematics and control algorithms. This is not the best way to make a precise double SCARA but it is a way to learn the closed loop control of a DC motor coupled with an encoder and at the same time the kinematics concepts in robotics.
Three libraries are needed to start running the program with the optical mouse:
If you want to control the robot with the mouse (It can be controlled with many other interfaces like touchscreens, joysticks or sending trajectories form a vector)  you need this library:
https://github.com/zapmaker/OptiMouse
The motor driver library (Other motor driers can be used such as L298N):
https://github.com/pololu/dual-mc33926-motor-shield
The PID Controller library to control the motor position in closed loop with the encoder position:
https://github.com/DonnyCraft1/PIDArduino
ino - 4.35 kB - 06/22/2020 at 20:33
Download
AutoCAD DXF - 22.36 kB - 06/22/2020 at 20:08
Download
AutoCAD DXF - 26.07 kB - 06/22/2020 at 20:08
Download
AutoCAD DXF - 24.30 kB - 06/22/2020 at 20:08
Download
AutoCAD DXF - 24.52 kB - 06/22/2020 at 20:08
Download
View all 11 files
View all 8 components
View project log
  • 1
    Step 1
View all instructions
Xavi Cano wrote 06/24/2020 at 14:39 point
Thanks! I am working on the next version with stepper motors and limit switches!
Dan Maloney wrote 06/24/2020 at 00:18 point
I've seen a lot of these that are very, um... "compliant". This one seems very tight. I'll bet it performs great as a plotter if outfitted with a pen. Nice work.
