Witches Brew V1.3 CV Joystick Controller
Let's you control any Voltage Control Synthesizer parameter with a Variable Voltage Output from +8V to -8V on a Joystick or other Controller
Based on CGS04 Joystick Controller Thanks to Kenstone for his work.
•1 x TL074 (DC Mixer)
•1 x TL072 (Voltage to Current LED Driver)
Features
•Clearly Labeled Sections on PCB/Schematic and low parts count for beginners.
•X and Y Axis CV for Joystick
•Panel Mounted Offset/Range Knobs X/Y Axis
•Offset Postive/Negative Voltage LED Indication
•Passive Attenuator Output
-Warning-
This is my first PCB and Design. Use at your own risk with off the shelf eurorack Modules. This is the first Version and works fine. But it is still A DIY Synthesizer and my modular and electrical Design skill are limited.
PCB is made too be stack able So you can house 2 joysticks in a controller for some dual CV Madness or have a joystick on a panel and a Separate 5 pin Din expansion jack for a wired controller.
V1.2.0
It worked as intended surprisingly:)
V1.3.0
Features
•X and Y CV for Joystick
•Offset/Range Panel Knobs X/Y
•Offset Postive/Negative Voltage output LED Indication
The Redone schematic for witches brew module. LEDs are now driven linearly. The LEDS Brightness Linearly controlled By Converting Voltage Output to Current method *So It can Accurately Display the Voltage on the LED.Also redone most of the artwork with better skills.
Also going to release the PCB files once finalized and maybe do some limited runs.
Schematic Witches Brew 1.3.0.pdf
Adobe Portable Document Format - 91.68 kB - 10/30/2020 at 20:20
Preview
Download
Schematic Witches Brew v1.2.pdf
Old version 1 PCB Schematic
Adobe Portable Document Format - 188.39 kB - 06/27/2020 at 23:10
Preview
Download
ms-excel - 3.14 kB - 06/27/2020 at 23:01
Download
Witches Brew Notes.docx
Just some notes and guff for V1.2
document - 12.37 kB - 06/27/2020 at 23:01
Download
  • 1 × Tl074 Amplifier and Linear ICs / Operational Amplifiers
  • 1 × Tl072 Amplifier and Linear ICs / Operational Amplifiers
  • V1.3.0 PCB Design
    Neil Mundt2 hours ago 0 comments
    After doing the PCB Layout and redoing some of the Artwork. I present you a very close Representation of what a final PCB will look like. I would like too thank Kristian Blåsol for his series Modular in a week for teaching me and pointing me in the right direction.
    Also LOOKMUMNOCOMPUTER for teaching how to motivate myself and not get down when things don't work as planned "Don't be afraid to try it." Been Though so many failed circuits and Burned IC's. But was able to make something out of it.
  • V 1.3 Redoing the LED Driver Circuit so it is properly Linear.
    Neil Mundt10/23/2020 at 03:14 0 comments
    So after some testing and Reading other methods of driving LEDs. I decided on Converting the output voltage to Current Source. That it would be the best way to Linearly display the output voltage. While my original idea did work to drive the LEDs they would Cut to zero Brightness(Lumis) still at 500mv output. That is because controlling it by voltage cannot be completely linear Due to the LED forward voltage. Now that I am controlling them by current we are actually able to accurately Display the voltage on a Blue and Red LED. Now that I solved that problem. I'll Re Design the PCB too incorporate these changes. It was pretty fun finding a fix for this.
  • 1.2.5 Revision/Beyond
    Neil Mundt09/05/2020 at 03:03 0 comments
    *Pcb fully functional as intended
    I will revisit this project later. I'll make some fixes on the PCB  and Release the PCB Layout.
    If I do Redo the LED driver and add some more features. I might sell some PCBS after that, But as it stands for now. I Personally Don't feel like I have changed too much from the original CGS Joystick Controller Design.
    ----Problems----
    -Hard to solder onto ground plane due too thermal conductivity of ground plane(Noobie's Bewares)
    -Fix PCB LED layout (switch X and Y axis with each other)
    -Fix PCB LED and capacitor foot print too more spacious
    -FIX PCB Layout (add OFFSET panel Control too PCB Mask layer)
    --Fixes--
    -Find Stand offs with proper clearance in metal variant(only pvc ones have proper hight for proper stacking.
    -add diodes or some ability to prevent LEDS from getting lfo or oscillator signal effecting LEDs brightness
    Later Revisions Features
    -Redo LED driver circuit so it is current controller making the led incantation linear (Doesn't Cut too 0 Brightness at 500mv)
    -Add optional always inverted output header
    -Add +/-8v LED Digital Display Voltmeter
    Red for +Positive voltage
    Blue for -Negative voltage
    I would Like too. Thank Kristian Blåsol for the mention on his channel. He has a great series called modular in a week with great projects. Learned Quite a bit from his videos here is  His Video On CV controllers/Joysticks
View all 3 project logs
