Witches Brew 1.3.1
A project log for Witches Brew V1.3.1 CV Joystick Controller
Let's you control any Voltage Control Synthesizer parameter with a Variable Voltage Output from +8V to -8V on a Joystick or other Controller
neil-mundtNeil Mundt 12/14/2020 at 01:170 Comments
After further use of the Witches Brew.  I decided that the passive attenuator section is pretty redundant with the range knob. No point in having it making things more complicated and take more time too build. I am also adding the Option to have a Inverted X/Y output. Too add more flexibility too the module.  Things have been Slow, But it shouldn't take long too redo the PCB. This is a great article about Offset Scalers. I found this when Modular in a week introduced me too that page and was a interesting feature too add.
