Witches Brew 1.3.1 PCB With Optional Inverted Output
A project log for Witches Brew V1.3.1 CV Joystick Controller
Let's you control any Voltage Control Synthesizer parameter with a Variable Voltage Output from +8V to -8V on a Joystick or other Controller
neil-mundtNeil Mundt 12/28/2020 at 23:040 Comments
I cleaned up the rats nest of traces. It seems it went quicker. Now have more experience with Easy EDA.
•Added a +12v copper infill on the Top Layer for the Power rail too clean it up a bit.
•Removed the Passive Attenuator, Because of testing I found it pretty redundant with already having a range knob. No need to complicate things.
