Buoy B V1.0 - Wiring Diagrams
A project log for 2020 HDP Dream Team: Conservation X Labs
The 2020 HDP Dream Teams are participating in a two month engineering sprint to address their nonprofit partner. Follow their journey here.
Leonardo WardLeonardo Ward 08/25/2020 at 16:380 Comments
The following diagrams present the physical connections of the different boards and components of the Buoy B V1.0.
Motors
The board was designed to handle 3 different types of motors, those are:
Battery Management
The original design of the board considered the following components:
Also, there is an alternative for the battery management, is possible to provide the required voltages with a boost converter and a 3.7V Battery, like the following example:
This alternative is valid and possible, but is not ideal for longer working time (compared to the first one). It is important to consider the efficiency of the boost converter. The selected boost converter will have a voltage drop at a current higher than 500mA, that should be taken into consideration.
