Onboard Gateway V1.0 - Assembly
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
leonardo-wardLeonardo Ward 09/16/2020 at 01:220 Comments
This log describes the recommended assembly instructions for the Onboard Gateway V1.0 PCB. The following image shows all the required components, with an identification number that will be used in the log.
Components list:
  1. TERM BLK 2P SIDE ENT 5.08MM PCB
  2. CONN HEADER R/A 2POS 2.5MM
  3. CONN HEADER VERT 2POS 2.54MM
  4. CONN HEADER VERT 2POS 2.54MM
  5. CONN HDR 6POS 0.1 TIN PCB
  6. 2POS JST cable (included in the USB LiIon/LiPoly charger)
  7. USB LiIon/LiPoly charger
  8. Onboard Gateway V1.0
  9. CONN HEADER VERT 2POS 2.54MM
  10. 250 Ohm Resistor
  11. 250 Ohm Resistor
  12. TERM BLK 2P SIDE ENT 5.08MM PCB
  13. CONN HEADER VERT 6POS 2.54MM
  14. CONN HDR 2POS 0.1 GOLD PCB
  15. CONN HEADER VERT 6POS 2.54MM
  16. CONN JUMPER SHORTING .100" GOLD
  17. CONN HDR 19POS 0.1 TIN PCB
  18. ESP32-DEVKITC-32D
  19. CONN HDR 19POS 0.1 TIN PCB
  20. CONN HDR 16POS 0.1 TIN PCB
  21. CONN HDR 12POS 0.1 TIN PCB (I used 2 CONN HDR 6POS 0.1 TIN PCB)
  22. CONN HDR 9POS 0.1 GOLD PCB
  23. CONN HEADER VERT 2POS 2.54MM
  24. CONN HEADER VERT 2POS 2.54MM
  25. CONN HEADER VERT 2POS 2.54MM
  26. CONN HEADER VERT 2POS 2.54MM
  27. 100 Ohm Resistor
  28. 100 Ohm Resistor
  29. 100 Ohm Resistor
  30. 100 Ohm Resistor
  31. CONN HDR 5POS 0.1 GOLD PCB
  32. RFM95W LoRa Radio
  33. CONN HEADER VERT 16POS 2.54MM (included in RFM95W LoRa Radio)
It is possible to solder the components in many different orders, I'll describe the one that I followed, it can used as a reference.
Instructions
a. Solder the female headers 17 and 19 used to connect the ESP32-DEVKITC-32D to the Onboard Gateway V1.0.
Once the female headers are soldered, the ESP32-DEVKITC-32D connects to the Onboard Gateway V1.0 through the headers.
b. Solder the female headers 22 and 23 used to connect the RFM95W LoRa Radio to the Onboard Gateway V1.0.
c. Solder the male headers 33 to the RFM95W LoRa Radio. To do that it is necessary to cut a CONN HEADER VERT 9POS 2.54MM and a CONN HEADER VERT 5POS 2.54MM from the component 33. Once the female headers are soldered, the RFM95W LoRa Radio connects to the Onboard Gateway V1.0 through the headers.
d. Solder the female headers 20 and 21 to the Onboard Gateway V1.0.
e. Solder the female headers 5 and 14, used to connect the USB LiIon/LiPoly charger to the Onboard Gateway V1.0.  After that it is important to solder the male headers 9 and 13 to the USB LiIon/LiPoly charger
The USB LiIon/LiPoly charger connects to the Onboard Gateway V1.0 through the headers.
f. Solder the male headers and terminal block connectors.
Solder the male headers 3, 4, 23, 24, 25 and 25, used to connect the leds in the enclosure (through an additional cable). Solder the terminal blocks 1 and 12. Solder the 2POS Horizontal JST-XH connector (2)
Solder the male header 15.
g. Solder the resistors used for the leds.
