Mechanical Design Specifications
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
ekEK 09/18/2020 at 18:540 Comments
The Eja ropeless gear system consists of three parts: Release Mechanism, Intelligent Buoy, and Onboard Gateway. Here are the mechanical design specifications for each, also available as a pdf here.
Release Mechanism
3D viewer: https://a360.co/3msDSha
Files: https://github.com/RobotGrrl/Hackaday-CXL/tree/master/Design/release_mechanism
Length
52.9 cm
Width
39.0 cm
Height
32.9 cm
Approximate Weight
15 lbs / 6.8 kg (including ballast)
Materials
0.375 in HDPE base, PLA 3D printed pieces
Max Depth
TBD
Eja Bill of Materials - Release Mechanism
Last Updated: Sept. 18, 2020
All fasteners for prototype are zinc-plated steel
Item
Qty
Cost (USD)
McMaster Part #
Source
Notes
M6 x 16 mm
32
3.32
90128A263
M6 x 25 mm
30
3.97
90128A265
M6 Washer
50
2.15
98688A116
M6 Hex Nut
62
1.61
90591A151
M3 x 10 mm
12
1.70
95263A134
M3 x 16 mm
12
2.11
95263A158
M3 Washer
28
0.96
98688A112
M3 Hex Nut
24
0.56
90591A250
Magnets N52 (large)
5
4.85
5862K116
TOTAL MECH COMPONENTS
21.22
0.375 in Natural HDPE 24 x 48 in
0.5
42.50
eplastics - San Diego
Cost / in^2 = 0.04
1 kg 3D Printer Filament PLA
2
57.98
Amazon
Misc. rope, cord, carabiner
1
5.00
Random
10 lbs Dumbbell
1
7.00
Canadian Tire
Spool holder
1
1.00
TOTAL MATERIALS
113.48
CNC machine time
20
20
DesignLab
1 / min
3D printer time
1200
60
EK's 3D printer
0.05 / min
Injection moulding time
0
0
Assembly time
90
22.5
EK
15 / h
TOTAL MACHINE TIME
102.5
GRAND TOTAL
237.20
Parametric Design
Here are the values used for parametric design
Intelligent Buoy
3D viewer: https://a360.co/3hJjc0R
Github: https://github.com/RobotGrrl/Hackaday-CXL/tree/master/Design/intelligent_buoy
Diameter
9.3 cm
Height
20.8 cm
Approximate Weight
500 g
Materials
Polycarbonate (‘Tritan’), PLA 3D printed pieces, Neodynium magnets, FR4 circuit board for structural strength
Waterproof Rating
Waterproof*
*Further testing is needed to determine depth
Eja Bill of Materials - Intelligent Buoy B
Item
Qty
Cost (USD)
McMaster Part #
Source
Notes
M2.5 x 8 mm
4
0.54
90128A184
M2.5 x 6 mm
14
1.85
90128A183
M2.5 Washer
4
0.13
98688A111
M2.5 Hex Nut
8
0.18
90591A270
M3 x 10 mm
4
0.57
95263A134
M3 Washer
0
0.00
98688A112
M3 Hex Nut
4
0.09
90591A250
Magnets N52 (small)
4
3.04
5862K103
Magnets N52 (large)
5
4.85
5862K116
11.24
Nalgene 1L wide mouth enclosure
1
20.00
SportChek
0.25
7.25
Amazon
Misc. glue, wires
1
1.50
Random
TOTAL MATERIALS
28.75
3D printer time
60
3
EK's 3D printer
0.05 / min
0
0
Assembly time
20
5
EK
15 / h
TOTAL MACHINE TIME
8
GRAND TOTAL
47.99
Onboard Gateway
3D viewer: https://a360.co/32DGUHE
Files: https://github.com/RobotGrrl/Hackaday-CXL/tree/master/Design/onboard_gateway
Length
15.6 cm
Width
8.5 cm
Height
6.3 cm
Approximate Weight
300 g
Materials
Waterproof Rating
Not waterproof
Eja Bill of Materials - Onboard Gateway
Item
Qty
Cost (USD)
McMaster Part #
Source
Notes
M2.5 x 8 mm
8
1.07
90128A184
M2.5 x 6 mm
0
0.00
90128A183
M2.5 Washer
0
0.00
98688A111
M2.5 Hex Nut
8
0.18
90591A270
M3 x 10 mm
4
0.57
95263A134
M3 Washer
0
0.00
98688A112
M3 Hex Nut
4
0.09
90591A250
1.91
0.75
21.74
Amazon
TOTAL MATERIALS
21.74
3D printer time
180
9
EK's 3D printer
0.05 / min
0
0
Assembly time
10
2.5
EK
15 / h
TOTAL MACHINE TIME
11.5
GRAND TOTAL
35.15
