Analysis of Field Test
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
ekEK 10/30/2021 at 19:080 Comments
There is a possible failure that could occur with the delrin pieces of the sleeve bearing. On landing, these pieces deformed quite a bit:
Based on the observation above of the delrin deforming, knowing the force of the landing could better inform the parameters for simulation. To calculate this, the velocity of the descent needs to be determined.
Descent Velocity
Observations from the descent of the robot can approximate the descent velocity in the water. A clip of the descent where the camera was somewhat stationary was chosen.
Between these two frames that are 2 seconds apart, we can see that the distance of travel is approximately 1 stand-piece-height. Each stand piece is 47.70 mm.
This means the robot travelled 4.77 cm in 2 s.
v = Δd / Δt
4.77 cm / 2 s
= 0.02385 m/s
The descent velocity is 0.02385 m/s.
Force of Landing
When landing the robot immediately stops to 0 m/s. For “immediately”, this will be approximated as 0.1 s.
a = Δv / Δt
0.02385 m/s / 0.1 s
= 0.2385 m / s^2
The acceleration is -0.2385 m/s^2. The mass is estimated to be 7.0 kg.
F = m*a
7.0 kg * -0.2385 m/s^2
= -1.67 N
Or, -4.44 lbf.
It is important to notice that in the video there was a rock on the seafloor protruding higher than the others. This meant all of the force was on 1 of the 6 stands for landing. Usually, this force would be distributed over multiple stand pieces.
An attempt was made to simulate the force using a FEA simulation in Fusion 360 with the hope of determining the amount of displacement of the delrin pieces. However, this was not able to be completed in a timely manner due to additional configuration that would be needed on the simulation.
Ascent Velocity
Although the ascent speed is not needed, it would be interesting to know while we’re at it.
Using the same process as above, two frames from a video where the camera is almost stationary were extracted:
Overlaying the two frames, using the height of the buoy, the distance can be calculated:
Tracking from the bottom point of the buoy enclosure, the distance travelled is 4.3 buoy-body-lengths. Each buoy body length (aka diameter) is 92.64 mm.
Total distance travelled = 39.8 cm.
v = Δd / Δt
39.8 cm / 2 s
= 0.199 m/s
The buoy ascends at 0.2 m/s. To travel the full length of the spool (30 m), it would take 150 s, or 2.5 mins.
Conclusion
To address the main issue at hand here about the delrin piece, two improvements are recommended:
  1. Add cushioning to the bottom of the stands (closed-cell foam)
  2. Increase material thickness of delrin pieces to 1/4"
Apart from that, more testing is needed to see where other parts break!
