GPS - ANTENOVA M20050-1 and ATGM332D-5N31 Dev Board
A project log for 2021 HDP Dream Team: EJA
Learn more about Team EJA's intelligent buoy, and how their solution will help the global fight against ghost gear.
leonardo-wardLeonardo Ward 08/06/2021 at 13:400 Comments
Similar to the development board that we designed to test the RFM95W (LoRa), we designed a new PCB for the ANTENOVA M20050-1 and the ATGM332D-5N31. Those are 2 promising GPS modules that we are considering to replace the module that we used in our previous design, the Adafruit Ultimate GPS.
The schematic is very simple, for each module we included a few decoupling capacitors, a U.FL connector for an external antenna and some headers to have access to different peripherals.
The design can be found in the following Github repository.
Schematic for the ANTENOVA M20050-1
Schematic for the ATGM332D-5N31
Also, we are going to test a couple of battery holders.
Bill of Materials
ReferenceQuantity
10 µF ±10% 6.3V Ceramic Capacitor X5R 0805 (2012 Metric)4
Red 630nm LED Indication - Discrete 1.9V 0805 (2012 Metric)1
U.FL (UMCC) Connector Receptacle, Male Pin 50Ohm Surface Mount Solder2
Battery Retainer Coin, 20.0mm 1 Cell PC Pin1
Battery Holder (Open) Coin, 20.0mm 1 Cell PC Pin1
Unshielded Multilayer Inductor 100mOhm Max 0805 (2012 Metric)1
1K ±1% 0.125W, 1/8W Chip Resistor 0805 (2012 Metric) Automotive AEC-Q200 Thick Film2
220 Ohms ±5% 0.125W, 1/8W Chip Resistor 0805 (2012 Metric) Moisture Resistant Thick Film1
0 Ohms Jumper 0.125W, 1/8W Chip Resistor 0805 (2012 Metric) Moisture Resistant Thick Film1
ATGM332D-5N31 GNSS Series GPS+BDS 12.2x16x2.4mm Satellite Positioning Modules ROHS1
Antenova M20050-1 series RF Receiver GPS 1.575GHz -165dBm - On-Board, Trace Module1
Conn Header 40POS 2.541
PCB
