Would you like to learn how to make a led chaser circuit using some transistor? LED chaser circuits are simple electronic circuits that usually find their use in advertisement and decorative purposes in places such as automobiles, Festivals & Home decor. So, in this project, we will design a LED chaser circuit using 2SC9013 NPN transistors.
Step 1: Hardware Required
To Buy Cheap Electronic Components Please Visit: UTSource
Step 2: Solder All Resistors
Step 3: Solder All Transistors
Step 4: Solder All LED's
Solder All LED's
Step 5: Solder All Electrolytic Capacitors
Step 6: Solder Terminal Block & Potentiometer
Step 7: Let's Test the Circuit
Step 8: Circuit Diagram
Circuit Diagram
