IR (Infrared) Remote Control Switch Circuit is a cost-effective solution for home appliances in our fast-paced life. As a result, much importance has been given to this aspect and a range of remote controls are prevalent today. One of the most frequent is that which makes use of IR radiations at particular frequencies for operations. So In this tutorial, we are going to make an “Infrared IR Remote Control Relay Module” by using TSOP1713 & CD4017 Decade Counter IC.
Step 1: Hardware Required
To Buy Cheap Electronic Components Please Visit : UTSource
- CD4017 IC with base
- 5v Relay
- TSOP1738
- BC547 NPN Transistor
- BC557 PNP Transistor
- 1n4007 Diode
- Resistors(220,1k,10k,100k)
- 1uf Electrolytic Capacitor
- Output LED
- 9v Battery with Clip
Step 2: Solder Relay
Step 3: Solder IC Base & Terminal Block
Step 4: Solder Transistors
Step 5: Solder TSOP1738
Step 6: Solder Output LED
Step 7: Solder Power Connector
Step 8: Add AC Bulb in Series With Output
Be Carefully dealing with 220v
