Janus Brushless Controller
The Janus Controller is a Brushless motor driver with an on-board magnetic encoder for position and velocity control.
Public Chat
If you want a shield type board this version is for you, if not new version of the controller: https://hackaday.io/project/174135-dagor-brushless-motor-controller
The Janus Controller is a Brushless motor driver with an on-board magnetic encoder, a three-phase MOSFET driver, three MOSFET half-bridges, a temperature sensor and current sensing resistors.
Janus Controller was designed to work with the ESP32 Dev-Kit1 as a shield so that the programing of the board is easier for hobbyist and students, and to bring down the overall price of the board. This board can be used to drive brushless motors as an open-loop system or use the on-board encoder to drive the motors as a closed-loop system and use more complicated algorithms, such as Field Oriented Control for position and velocity control. I recommend using the Simple FOC Arduino library as it has shown to work perfectly for position and velocity control and is easily implementable, but you can always use your own algorithm.
  • 1 × DRV8305 MOSFET gate driver
  • 6 × NVTFS5C453NL N-Channel MOSFET/ 3.1mhom
  • 1 × MA730 Magnetic Encoder
  • 1 × MCP9701AT Sensors / Temperature
  • 1 × ESP32 DEVKIT V1
View all 6 components
View all 3 project logs
zhuangfengzi wrote 10/19/2020 at 07:26 point
What are these mistakes? How to solve this problem? thank you!
E:\xxxxxx\esp32\Janus-Controller-master\JC01F05\JC01F05.ino: In function 'void setup_MCPWM()':
JC01F05:379: error: 'MCPWM_SELECT_SYNC_INT0' was not declared in this scope
exit status 1
zhuangfengzi wrote 10/19/2020 at 14:51 point
@Paul Gould
    Thanks a lot!
David Gonzalez wrote 10/19/2020 at 16:14 point
Yes, Paul found a mistake on the mcpwm.h file as shown on his project log. Thanks Paul.
Steven wrote 09/20/2020 at 09:53 point
How much does it cost to produce the controller?
Owen Williams wrote 08/23/2020 at 17:10 point
Have you tried out your new board?  I was wondering whether your changes have meant that current sensing is now working?
David Gonzalez wrote 08/23/2020 at 23:08 point
I don't think I will order the corrected version of this controller. At the moment I'm putting all my resources in the following version of my BLDC controller. https://hackaday.io/project/174135-dagor-brushless-motor-controller
