Fixing Play in the Spindle Mount
A project log for Chad, the Desktop CNC Mill
Spending hours soldering perfboard has done my head in for years. Chad is the perfect solution, allowing quick PCB prototyping.
sam-griffenSam Griffen 07/03/2020 at 11:030 Comments
The original build never gave incredibly good results, with the bit either not cutting into the copper, or pushing too far through and ripping the board up, not creating viable traces. When it did break the surface, there was a lot of vibration in the tool, causing inconsistent lines. This is shown in the image below:
After some prodding, it seemed that there was a lot of play in the Z axis, due to the shaft coupler having a spring, rather than being completely solid. I had used a coupler like this one:
Aluminum Flex Shaft Coupler - 5mm to 10mm - BC RoboticsThe culprit of Chad's inability to make nice boards?? I have a couple of solid aluminium couplers in the mail to replace the Z axis coupler, however in the meantime I have printed a placeholder coupler in PETG, and fitted that to the axis. No longer is there play in the tool, it is mounted very rigidly, and the results are very clean:
First test with placeholder coupler. (Board is a supercapacitor charge circuit)
The resulting board is significantly cleaner, and would actually be functional. I'm excited to mill further circuits, I will update once I have a larger board milled.
