Analog Clock Motor Driver
Implementation of all the active electronic functions needed in an analog clock, including motor driver and crystal oscillator.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Even in a digital world, classic analog clocks have a timeless style that is here to stay. We can use a dual-rail GreenPAK™ CMIC to implement all the active electronic functions needed in an analog clock, including motor driver and crystal oscillator. GreenPAKs are low-cost, tiny devices that fit right in with smartwatches. As an easy-to-build demonstration, we obtained a cheap wall clock, removed the existing board, and replaced all the active electronics with one GreenPAK device.
Check out the app note for more: https://www.dialog-semiconductor.com/AN-CM-241
